Old 24-Nov-2005, 18:20   #11
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
yes the lines are still attached, I'll remove the pads then.
Cheers for the info
Old 24-Nov-2005, 20:52   #12
keefer keefer is offline
keefer's Avatar
Originally posted by skidlids
I was wondering what you were on about Dave
As for cleaning Brakes Keefer is the man to ask
lol
skids provided me with the dirtiest brakes ever.
as you have said remove the pads
then mix up some T-cut with meths and work it into the calliper with a toothbrush, keep you bucket of hot soapy water handy and give them a rinse every now and then,
you will be amazed how bright they are when you finish
Old 25-Nov-2005, 09:31   #13
rcgbob44's Avatar
I use Gunk or Holts engine clean and a stiff bristle brush, not a wire brush, rinse well and they look like new.
Have a nice day!
Old 29-Nov-2005, 16:06   #14
dave996's Avatar
Mood: Fed up...
Worst case scenario has happened
I was pumping the pistons out on the caliper in the soapy water being carefull not to close the pistons on each other and one popped out, befor I realised this had happened I had already given it a couple of pumps on the leaver
HELP WHAT DO I DO NOW, is it all f**ked or can it still be saved?
Dave
Old 29-Nov-2005, 16:11   #15
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
While it was in a bucket of water, doh!
Ah, well; trip it completely and get all the fluids out. Can't leave any water or contaminatd fluid in the casting.
Might as well pop all the pistons out know, too. They'll go back in easy enough, lubed with brake fluid or red rubber grease.
Rgds, Rob
Rgds, Rob
[Edited on 29-11-2005 by Rob B]
Old 29-Nov-2005, 16:12   #16
keefer's Avatar
as above disconnect it strip it down and leave to dry in the airing cupboard
Old 29-Nov-2005, 16:12   #17
dave996's Avatar
Mood: Fed up...
Cheers Rob.
Thanks for the speedy responce
Old 29-Nov-2005, 17:59   #18
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
Originally posted by Desmo748
...Squeeze the lever until the piston is far out as you dare...
Don't worry they will go back together again, once dry.
Old 29-Nov-2005, 18:03   #19
Harv748 Harv748 is offline
Harv748's Avatar
I know this doesn't help....but...
Old 29-Nov-2005, 18:23   #20
RickyX RickyX is offline
RickyX's Avatar
Make sure there is no cleaning substance residue left in the caliper piston bores before reassembly - residue may not react well with brake fluid.
I don't know the composition of Finish Power Ball Tabs but I doubt that it has been designed to work with DOT4 Fluid.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:57.
