Old 02-Dec-2005, 14:27   #11
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Also, you should only use resistor-type plugs in a Ducati 8xx bike. The main concern is with the computer found used on fuel injected bikes as the radiated EMI can interfere with the computer and corrupt signals which can affect engine performance and reliability. Theoretically, non-resistor plugs can provide more power, but the reality is that the ignition noise they produce can corrupt computer signals.
---> What about NOLOGY kit, then ???
Old 02-Dec-2005, 15:19   #12
Nology's claims are rebutted by Magnecor, a competitor - so form your own opinion.
http://www.magnecor.com/magnecor1/truth.htm
Scroll down to "capacitor effect wires."
The often-stated concern on Nology wires is that they're hard on the charging system. But, I can’t see how Nology wires will have an adverse effect on the charging system, since the coil primary resistance is what affects the charging system via the amount of current draw.
The Nology wires are an inline resistive-capacitive delay line in the spark plug wires. They have you put in a 1Kohm resistor in line then via the shielding, shunt the spark energy to ground via a capacitor. Initial voltage is about 70% of actual with a typical RC network slow decline. It seems to me that he only time an engine could benefit from this is if the timing is too far advanced.
Still, why install an inline 1,000 ohm resistor with a capacitive shunt to ground in your transmission lines? They aren't installed as original equipment by any manufacturer that I’m aware of. For every claim of an improvement, there are four more cases where nothing happened. I'm in the nothing happened category. I have never seen a bona fide improvement after changing to Nology wires.
Nology coils seem to work fine however. They are designed to be a pulse coil, which is something fairly common in EE design, but have no experience with the design. Unfortunately, even though they are allegedly the same 3ohm primary as the Dyna coils, the Nology Pro Fire coils seem to short and melt out ignition modules on 1994 and newer carburetor bikes.
The criteria for any good ignition wire is:
1. It has very low DC resistance
2. It has very low EMI and RFI interference
3. It is extremely durable and heat resistant
All of these factors are important. Most important is the combination of DC resistance (which cuts spark power directly) and interference, which can cause errors and irregularity in your timing and ECU operation. If you have any kind of electronic ignition or fuel injection, this is very important. You might say "well, my bike runs fine", but even a little bit of interference can misrepresent sensor readings and so on - it's not enough to make your bike not run, but it can and will affect your fuel economy and power. Straight wires (like Evoluzione's) have good DC resistance characteristics, but they have horrible interference problems.
Pressed, I have to say I prefer Magnecor over the other aftermarket wires.
Old 02-Dec-2005, 16:46   #13
phil911's Avatar
Very, very interesting ...
Nology kits currently fit my road T.8 and Racing 1993.
Bikes are top serviced by myself and I confess I'm not able to provide a rational point of view about the intrinsic qualities of the wires.
I'll try a Magnecor set ... later on.
... Thanks for the link provided !!!
Old 04-Dec-2005, 02:30   #14
loony888 loony888 is offline
Mood: sensational!!
i use champion a55v surface discharge plugs. i don't think they are a resistor type plug but i've used them for years with no probs.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:57.
