Old 01-Dec-2005, 17:42   #11
loverobot's Avatar
the links are not for dp items - the second states this is the case - the first doesnt say that they are so one can assume they are not?
Old 01-Dec-2005, 17:52   #12
Felix Felix is offline
You are correct, of course. I was mislead by the DP background packaging.
Old 01-Dec-2005, 17:53   #13
loverobot's Avatar
i do think dp do them though dont they? which probably means they are ok?
i have been thinking of the same myself but havent found any dp ones to buy
Old 01-Dec-2005, 17:58   #14
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
not least because it tends to tighten itself up to mega tight
Can't say that I've ever come across this, if anything I find that the wheel nut tends to loosen rather than tighten.
Old 01-Dec-2005, 18:01   #15
loverobot's Avatar
couple of people have mentioned this to me (on this board i think) and suggested the nuts were so tight thatthey snapped a breaker bar trying to get the thing undone
i have not found mine to that tight
Old 01-Dec-2005, 18:07   #16
The race hub are reverse thread and they get fukcing tight!
Old 01-Dec-2005, 18:08   #17
loverobot's Avatar
lol
that explains it then!
reverse thread = mondo torque !
Old 01-Dec-2005, 19:09   #18
DSC Member 916Neil 916Neil is offline
916Neil's Avatar
Mood: Waiting for summer
Ducati Performance do sell Titanium wheel nuts, would not like to hazard a guess at the sort of price they charge though. A pair sold on ebay last week for £73 plus postage.
I find that my Standard wheel nut tightens itself while the sprocket side slackens itself. Need to check and re-torque both every 1000 miles else sprocket is finger tight and wheel side virtually impossible to remove.
You might want to check out what pro bolt say about titanium fastenings. Would not think that they would be keen on the statement that replacement of steel with titanium is not the way to proceed.
Old 02-Dec-2005, 09:35   #19
loverobot's Avatar
Notice you are in west yorkshire neil - whereabouts? I am based in Guiseley
Old 02-Dec-2005, 10:07   #20
There are a couple of points here, the strength issue mentioned by Shazaam is the reason certain areas of the bike (brakes mainly) are included in the ACU Handbook where it is classed as unsafe to use Titanium fittings and is therefore against the rules.
Then there is the point of Production costs which is often the reason why less exspensive materials are used although more exotic materials would work just as well.
I have always taken note of the ACU ruling on Titanium fittings and use it as a guide.
For that matter I have had a alloy rear wheel nut on my 998 for the past 6 months without any problems.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:23.
