Old 03-Dec-2005, 20:26   #11
GsxrAge GsxrAge is offline
GsxrAge's Avatar
I have never in 15 years or so had a bike fail
(even with loud cans etc )
Old 03-Dec-2005, 20:33   #12
Steering head bearings - hard to check properly without cranking it up onto the side-stand (which is the method most MOT testers seem to prefer )
I thought mine were ok - but they were indeed notched right in the straight ahead position.
Shock mounts and swingarms could be worth a check as well.
Good luck - Frank
Old 03-Dec-2005, 23:35   #13
rcgbob44's Avatar
Age996
Ditto!
Old 04-Dec-2005, 02:15   #14
GsxrAge's Avatar
Originally posted by rcgbob44
Age996
Ditto!
Well apart from the race cans and small plate mine should go through But would any of us ride if they wernt upto and above Mot standard ?
The Mot is a good thing but Most peeps on bikes love em and slave all day to keep em looking like new, Unlike cage drivers
Old 04-Dec-2005, 04:39   #15
moto748 moto748 is offline
Thanks guys.
The steering head bearig s are new, and I had a good go at bleeding the back brake last week. Should be OK.
[Edited on 4-12-2005 by moto748]
Old 04-Dec-2005, 13:11   #16
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
Faulty rear stop light cured with wd40
Old 04-Dec-2005, 13:50   #17
YMFB YMFB is offline
YMFB's Avatar
over the years I have had bikes fail on most things but the worst was brakes, when I left for the MOT they were fine but most have been on the way out as the guys walked back in and failed it for having brake fluid all over the front discs.
Good luck
Old 05-Dec-2005, 01:00   #18
BDG BDG is offline
BDG's Avatar
Mine failed because when i got the MOT over the phone he posted it to the wrong address
Only joking.
Old 05-Dec-2005, 18:54   #19
Monty's Avatar
Checked my old (1952) Gilera Saturno out before it's MOT in September-rear light not working. Bloody bulb thinks I taking the lens off-not the bulb, the whole dam light unit, bulb holder the lot was missing-must have vibrated off. Put a modern LED type inside the old housing-looks standard still but that 'bulb' will never blow.
John
Old 06-Dec-2005, 08:15   #20
uncle porry uncle porry is offline
uncle porry's Avatar
Originally posted by nelly
The number plate light is checked.
Usual failures I see are front wheel bearings, head bearings, loose engine mount bolts (ST's most popular for this for some reason) and the rear brake on 748-996's.
If they're really tight, then headlight beam alignment.
no number plate light on mine, was told by mot bloke that its ok. if it had a light, and it was faulty, then it would fail the mot
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:14.
