Old 27-Dec-2005, 12:55   #11
Mr_S Mr_S is offline
Originally posted by keefer
light flywheel
May be able to ditch the flywheel completely
Old 27-Dec-2005, 13:06   #12
m1keyp m1keyp is offline
If you are buying the exhausts new get the Arrows, they are "E" marked with removeable baffle and sound great officer
I have a 40 tooth rear sprocket (748S) and its great fun, in an ideal world I would have an 853 conversion but Santa seems to have missed me out
Old 27-Dec-2005, 13:43   #13
keefer keefer is offline
keefer's Avatar
light flywheel
unlikely with a 2000 spec model
Old 27-Dec-2005, 16:16   #14
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
I have a 14/40 sprocket set up, which I recommend - £220 inc new chain, sprockets and quick release carrier.
Open pipes and chip.
Open air tubes with velocity stack filter.
Next for me is 853 pistons in summer but this will depend on your budget.
Old 28-Dec-2005, 09:17   #15
Delooney Delooney is offline
Delooney's Avatar
Mood: Just the one bike for me now
I would go one more and fit a 41 tooth rear.
Top end suffers more but how often do you really want to go above 140 ?
I find this the best way to stop you doing it with more fun in between !
Delooney
Old 28-Dec-2005, 10:51   #16
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Ive got a few sets of 50mm termis if you can find the header pipes off another bike...get it breathing like a goodun !! Also got some brand new ducati performance chips for the 748 (£20) which will help with open cans..
Think its only the earlier bikes where you can completely remove the flywheel..?
Nat
Old 28-Dec-2005, 18:37   #17
Mr C Mr C is offline
Buy a 996
Old 29-Dec-2005, 10:32   #18
deej deej is offline
deej's Avatar
do the 853 option, i did and its ace, not cheap but worth the money, by the time i add a power commander it will be making more than a 916 of the same age. then run 14/41 sprockets and you'll be laughing your ass off
would a power commander be a better option over a fim ultimap chip ???
Old 30-Dec-2005, 16:04   #19
cjsperf cjsperf is offline
the fim chip is also adjustable by ignition so small gains can be found over the pc3. however there are only a couple people with the ultimap software to adjust them. dynojet have released there ignition box to be connected to the pc3 to map ignition and raise the rev limit its around 200 quid and i will be testing it next month.
Old 30-Dec-2005, 22:55   #20
deej's Avatar
hiya chris, good xmas ???
got me self a pc111usb off ebay for £60 so that answers my own question as i remember you saying it was easier to refuel a pc111 if i can afford to get you to do anymore engine work that is.
where would you recommend to take the 853 to,to get the pc111 set up properly ??
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:09.
