Old 22-Aug-2003, 15:57   #11
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello yella,
I must agree with Guido, I had an oil light come on for no apparent reason (oil level check before ride out) and the bike eventually came to a stop.
The result main bearings gone, I dropped the oil and found most of the bearing gasket in bits in the pickup filter.
I know the oil switch is a problem from other posts, but from talking to people the oil pump are not a common problem, I have the old lump on a bench in my garage and when time permits will try to get to the bottom of why my engine failed.
Although I am prity sure it would have been a pressure problem
Don't wanna put the begeeses up you but if you are concerned maybe an early oil change is in order . .
I hope for you sake its something worked lose . . .or as stated a new oil switch in order.
regards
TopiToo
Old 22-Aug-2003, 16:08   #12
Bikes: 748ish . .
Sorry just out of intrest . .
More so for Shazaam!
If it was to be an oil pressure problem how is this fixed and more importantly why does it happen in the first place, as I have heard of more than one bike with this problem, is it to do with seals/gaskets? and the heat generated with these engines?
regards
TopiToo
Old 26-Aug-2003, 21:30   #13
Yellow Bip Yellow Bip is offline
Mood: tired!!!!!!!!!
just to update on this problem, I got a mate to do the pressure testing for me as quoted by shazzam and everything is in working order, so it could be the switch which i will be replacing when i get one from dibble. on inspection the vertical head at the back where the engine has lots of troughs where full of oil, now i have known for sometime that teh base gasket has been seeping oil but didn't think it would of leaked that much as i check level everytime i ride.
But went on a ride on sunday for 100 miles and not a problem.
if any one has any more suggestions that would be great ( and apart from changing gasket as nelly is doing this in a few weeks for me ).
Thanks for your input guys.
Old 28-Aug-2003, 08:33   #14
Guido's Avatar
Sorry YellowBip but.........change the seal/gasket.
About the only way to stop it really. I had mine done only last week for the exact same reasons as you. Luckily it was under warranty.
Old 29-Aug-2003, 18:27   #15
Cheers mate ( Guido ) is booked in for Nellys later next month.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:06.
