Old 06-Jan-2006, 20:43   #11
david.hicks david.hicks is offline
david.hicks's Avatar
BTW - I do love my SPS but those faint stains you can see on the pages were not made by me
Old 06-Jan-2006, 20:43   #12
keefer keefer is offline
keefer's Avatar
Originally posted by andyb
Awful, for a start it is using the steep head angle.................
yep I saw that and didn't even bother with the rest
Old 06-Jan-2006, 21:43   #13
Mood: childish
whats wrong with the steeper head angle?
Old 06-Jan-2006, 22:25   #14
ducv2 ducv2 is offline
Think the steeper head angle is better used with the longer swingarm and different shock linkages. If you do change the head angle, it will slap a bit, even with the steering damper. It will also feel like it is tucking in on slow corners on a neutral throttle
Old 06-Jan-2006, 22:27   #15
it shorterns the trail to much
Old 06-Jan-2006, 22:29   #16
GsxrAge GsxrAge is offline
GsxrAge's Avatar
yeah forget those settings go back to standard and adjust to suit you.
Old 07-Jan-2006, 10:17   #17
I assume the standard settings are detailed in the manual - unfortunately I haven't got one (its on order). I do have a Haynes however, does anyone know if the standard settings listed in there are correct?
Old 07-Jan-2006, 15:52   #18
The Owner's Manual lists the stock suspension settings. You can download it here:
http://www.ducati.com/bikes/manuals.jhtml
Old 07-Jan-2006, 21:50   #19
greenmachine greenmachine is offline
Mood: Flatulent
For what it's worth i set up my R6 and ZX7R per the PB guides with wonderful results on road and track. I'd personally gice it a go and see how you get on if you fancy fettling one afternoon.
I'd have a ride on standard settings first though as a bench mark - you can always return it to standard again.
Things like wear&tear, rider weight, tyres etc will all make a difference to some extent. And a good set of tyres which you are confident with are worth a thousand times more than a fancy suspension set up IMHO.
Good luck and let us know how you get on mate!
Old 08-Jan-2006, 21:13   #20
Webcore Webcore is offline
I tried the PB settings and didn't really like them - Wilf at Moto Rapido gave me a base setup that worked far better.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:00.
