Old 10-Jan-2006, 17:56   #11
loverobot's Avatar
cheers harv
Old 10-Jan-2006, 20:09   #12
m1keyp m1keyp is offline
My 748s came with 748E headers (from the factory) they are different and the 748E headers cannot be altered 45mm to 50mm (male female stuff).
Once we discovered tis the unrestricted link pipe etc makes a big difference
Old 10-Jan-2006, 22:32   #13
loverobot's Avatar
http://i20.photobucket.com/albums/b2...e/PA230009.jpg
what do you reckon? baffled and what size?
Old 10-Jan-2006, 23:38   #14
Harv748 Harv748 is offline
Harv748's Avatar
Yep...definately the original link pipe.
And as the slip on cans...well...slipped straight on, I can only assume they must be 45mm at the joint.
So the question is, can you get a 45mm straight through link pipe?
I know there are 45 to 50mm links, this is common...but 45mm straight through???
Old 11-Jan-2006, 09:31   #15
loverobot's Avatar
hmm
can anyone shed any light on this and as to whether such a one exists ?!
Old 12-Jan-2006, 23:20   #16
greenmachine greenmachine is offline
Mood: Flatulent
I have a similar setup with 45mm carbon termis on my 996. In stead of changing immediately for a 45/50mm half system (which i plan to do), is it not possible to remove the baffling from the 45mm link pipe? just asking before i set about dismantling everything. Anyone done this?
I'm glad someone pointed this out otherwise i'd probably not have twigged the link pipe was baffled. Cheers.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:15.
