Old 17-Jan-2006, 19:21   #11
phil_h phil_h is offline
phil_h's Avatar
Originally posted by domski
Bugger!!
I love it when you talk technical
Hmm - I wonder if you can easily fit different ends to ohlins ?
I need a nice 330mm shock for the SS
Old 17-Jan-2006, 19:32   #12
domski's Avatar
Originally posted by skidlids
and a 916/996/998 Ohlins DU-143 is 305mm with a 71mm stroke
So one of these would fit then?
I don't get my hands dirty, that's why I have 'technicians'
Old 17-Jan-2006, 20:39   #13
paynep's Avatar
Mood: Wet wet wet
Bugger!!
Double bugger!
I was going to use a 620ie shock on my SS
Old 17-Jan-2006, 23:44   #14
Richard at Harris performance will modify Ohlins shocks, so you could get a fork end changed for e rod end or vice-versa. Also longer or shorter damper rods and be fittted.
Alternatively shocks which alread have a ride height adjuster fitted could no doubt have a extension bit added (bit like the ones we had for DT175MX's and similar principle to the jack up adapters for early monsters)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:59.
