Old 17-Jan-2006, 23:10   #11
Im only saying what i was told, I know which way ill be fitting them. :P
Old 17-Jan-2006, 23:19   #12
Harv748 Harv748 is offline
Harv748's Avatar
I could tell you weren't paying attention during the presentations...
Old 17-Jan-2006, 23:21   #13
Me? With my reputation..........
Old 17-Jan-2006, 23:34   #14
yeti yeti is offline
yeti's Avatar
If you need to undo the pinch bolts, they are too tight and are deforming the axle. I don't care what Johnny Hackett says, there is no way the axle should deform at the torque these bolts are done to.
FWIW on my track bike, I made them a loose fit in the axle and ran a bolt between the two protectors to hold them in place, made the job a lot quicker when swapping from slix to wets.
Old 18-Jan-2006, 00:36   #15
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Without gong all through the previous posts to see if ths has already been mentoned but!!!
Ohlins axle and Showa axle's have different diamaters I believe. When I bought mine Dave asked me what forks are they for. I then bought another set to replace the damaged one and did not menton I had Ohlns forks. The second set are a loose fit, remedied by wrappng P.T.F.E tape around the stem. So if you are fitting bungs that are meant for Ohlns forks, this could be your problem.
Old 18-Jan-2006, 00:56   #16
Harv748's Avatar
Really?
I thought the spindles were the same...I'm 99.9% sure my spindle came from the showas that were originally on my my bike???
Old 18-Jan-2006, 10:06   #17
chief chief is offline
chief's Avatar
Mood: Either bemused or indifferent
Andy B is right guy's .............YOU HAVE TO LOOSEN THE PINCH BOLTS...............
I have ruined a pair already by hammering the little buggers home...... A little turn of the pinch bolt and hey presto.................
Old 18-Jan-2006, 10:10   #18
There is a god.................
Old 18-Jan-2006, 11:06   #19
I'd imagine the spindle/axle size would be the same, otherwise your front wheel would need to be different from fork to fork???
Saying that mine went in straight away on the 999, but Bob struggled to get them in, I ended up cutting a cross down the length of the bung which allowed the last few mm's to drift in
Old 18-Jan-2006, 13:08   #20
Twinfan Twinfan is offline
Twinfan's Avatar
Cheers - any idea on the torque for the pinch bolts????
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:49.
