Old 24-Jan-2006, 12:02   #11
I use longer bars at £22 a pair, by the time I sell the standard ones on they cost me next to nothing
Old 24-Jan-2006, 16:29   #12
Jasper Jasper is offline
Jasper's Avatar
I wound the lock stops out so that the bars locked out before the m/c hit the clocks.My logic being,that even though i had reduced my steering lock with the stops,the end result is the same when they hit the clocks!!Also,gained a bit extra by dropping the leaver slightly.
Old 24-Jan-2006, 16:42   #13
mikesps mikesps is offline
Where to find the longer bars? My throttle grip is an inch further out than the bar-end plug after fitting a PI radial master cylinder.
Old 24-Jan-2006, 17:08   #14
got a Mate that makes replacement ones for Harris Clip-ons, i get hold of a pair before he puts the locating groove in as its in a different place on the Harris ones, then I have to taper the end slightly and add the groove in the right place to suit the standard Ducati clamps.
Old 26-Jan-2006, 12:02   #15
Pete A Pete A is offline
Pete A's Avatar
The method I used to lengthen the standard bars was to remove the original plastic end plugs and machine up some new longer ones in ally. which I then loctited in place.
Simple if you've got access to a machine shop, or a mate that does.
Old 26-Jan-2006, 22:15   #16
Stealth Stealth is offline
Bikes: 998R, Panigale S
Stealth's Avatar
I have the same problem with clutch and brake radial m/cyls. Eventually went for Harris bars which I actually find more comfortable.
Old 30-Jan-2006, 23:07   #17
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Im making a set of longer bars up on my old mans lathe.
Aircraft spec alloy........................................
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:57.
