Old 24-Jan-2006, 17:03   #11
You need to be able to walk the bike off the trailer by standing beside it on the trailer. Standing on the ground makes you too low and its easy for the bike to fall away from you. Even at 6'2" tall that happens. Some of these skeleton type trailers are very hard (like the Dave Hindle (sp?) types) plus i've seen some designs that take three people to get the bike off.
I can move the channels around on mine to carry either one or two bikes, the loading ramp takes up the vacant third position, either in the middle or on the right.
Built in lighting is a much neater solution than a trailer board.
I think if you can do all that for £180 then your onto a winner!
Old 24-Jan-2006, 17:51   #12
kwikbitch's Avatar
All above points taken into consideration I might be interested!
Old 24-Jan-2006, 18:51   #13
Animal Animal is offline
Animal's Avatar
I'll have one!
Old 24-Jan-2006, 18:56   #14
butch890 butch890 is offline
Mood: Enjoying Togdom !
as long as the double can be used for one bike as well you can put me down for one
Butch
Old 24-Jan-2006, 20:00   #15
Harv748 Harv748 is offline
Harv748's Avatar
OK guys...been looking a bit more into this and to make it viable, the design will probably be so that you can alternate between it being a one or two bike design, i.e. the ramps will be fixed in such a way as to me 'moveable' when required.
Still working on it...but keep the interest coming...
Old 24-Jan-2006, 22:07   #16
Email on the way Harv.
Old 24-Jan-2006, 22:14   #17
the phantom pieman the phantom pieman is offline
the phantom pieman's Avatar
Mood: Sort of shuffling along .....
Would be interested ... Can I take it that "proper wheels" will be used rather than the onces you find on wheel barrows ?
Old 24-Jan-2006, 23:48   #18
gaz3014 gaz3014 is offline
gaz3014's Avatar
Mood: On the edge
I would definatly be interested in a single bike trailer!!!
Was going to get one this spring, but will hang on for a bit.
Any idea when you will be putting them together???
Old 24-Jan-2006, 23:55   #19
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
HARV, would you be using 500 or 750 KG indispension units?
the reason i ask is i have towed with both, and found that the 750kg units are more robust
but the suspension effect works better on the 500kg ones
the 250kg ones are crap!
whats your thought mate?
mav
Old 25-Jan-2006, 10:17   #20
Harv748's Avatar
Gaz...at the moment I am trying to guage if there is enough interest to get this going. As with all ventures like this, it comes down to demand...if enough people show interest then the cost of production becomes less, and the better the savings etc etc...
At the moment I have about 7 or 8 people interested, if I can get that upto double figures then it should be a goer...although it does still very much depend on the final spec and the ability to obtain the parts at good prices.
I'm meeting with my mate over the weekend to hammer out the details and put some designs/figures together. Therefore I should be able to get back to eveyone next week with a plan or not!
Mav...I think due to trying to keep a limit on costs, and because they will be fine, we would go for the 500Kg units. I have a trailer with 350 units on, and its been working fine for several years...with no issues whatsoever. I see no reason to use heavier rated and more expensive units on a tailer designed for a max of two bikes (max weight 400Kg)...so it will probably be 500Kg units.
As I say...details to follow.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:15.
