Old 20-Aug-2003, 13:57   #11
The first few plates, and steels are easily removed, once you get further into the basket, they get a bit fiddly...
I cut down a wire coat hanger, and bent it into a handle shape, and then bent both ends to create small tabs, which can easily hook behind each plate, allowing quick/easy removal...
Old 20-Aug-2003, 15:24   #12
keith_mann1959 keith_mann1959 is offline
Bikes: ST4S
keith_mann1959's Avatar
Mood: Finally gotten over the 748R getting stolen thing. Actually, no i haven't !
Dry clutch's are designed to run "open" arent they. As delivered new they will run too hot behind that cover. Eurocrats are not interested in the long term health of your clutch. They just want you to be quiet. Let it breathe.
Old 20-Aug-2003, 17:07   #13
Marty916 Marty916 is offline
Dry clutches do better when cooled, as mentioned by Keith. The covers are closed to help reduce noise emissions and keep the elements from attacking the works. You could install a vented or open cover to help cool the clutch or if you're a cheap ******* like me you can simply put some spacers between the cover and case. With your consistent wet weather, I would be sure to inspect the clutch often to verify that the works aren't rusting together should you go for an open/vented cover. That tool you saw was in fact the holding tool for removing the clutch hub and has no bearing on the clutch plates.
Old 20-Aug-2003, 17:26   #14
ST4 ST4 is offline
I think the real reason for a open style cover is to let the dust out rather than to keep it cool.
Old 20-Aug-2003, 23:08   #15
Sticky Sticky is offline
Sounds like a good reason to tell the wife that I need to buy a ventilated clutch cover. Are you sure I don't need a slipper clutch aswell???
Old 26-Aug-2003, 00:25   #16
billy billy is offline
Mood: safe
my clutch was slipping in hot weather on my 996, fitted an open cover - problem sorted
Old 26-Aug-2003, 14:51   #17
rcgbob44's Avatar
Got to add my bit here!.
Since I bought my 998s last year i have hated the clutch. It judders and grounches all the time and i get out accelerated by milk floats with flat batteries!. Took it to my dealer who said its was ok and there all like that.
My Jota clutch runs in oil and is super smooth all of the time so I have to ask "are all dry clutches so lousy"?
Old 26-Aug-2003, 14:52   #18
rcgbob44's Avatar
Sorry forgot to add that I think the clutch is shite! any adeas would be much appreciated.
Old 26-Aug-2003, 14:55   #19
Guido.....
...are you actually using the clutch???
Its that silver lever near the left hand clip-on
Old 26-Aug-2003, 14:56   #20
rcgbob44's Avatar
But I thought all dukes were automatics!!!!!!!!!!!!!!!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:33.
