Old 26-Jan-2006, 23:16   #11
DSC Member AK AK is offline
AK's Avatar
oy payne!:P
you mis-read the posts dear - wasnt that you?? (and you even tried to lower your even more by squashing the tank, so less got through
48 at Cadwell Woodlands, if you dont mind, 52 with 675, then a tad more with the 620 lump in her... now 620 engine sold (to a lucky racer) and back to good old 583 again
Old 27-Jan-2006, 14:43   #12
Fiver Fiver is offline
Fiver's Avatar
Mood: gutted.
Originally posted by monstermob 998
when you start from cold you arent making the same mistake as i did when i first got my 600? what i was doing was giving it full choke and just a blip on the throttle motor spun over but didnt fire- an hour later i decided to try different tactics put it on half choke and just pushed the button without touching the throttle she fired up a treat - works every time now!!(tempting fate)
ya know, i think it may well be something like this that im not doing right.
It still won’t start. Ive tried the choke thing, but i need to charge the battery now as its getting a touch low (will do tonight)
Firstly, sorry for all my questions.
I hate being a newbie, and i feel like a total dumbarse asking so much, but i feel its better to ask than not, and im gonna use the "its my first bike" thing for as long as i possibly can haha
When i turn the ignition on, when its on the stand - the hazard light (stand down) and the oil light illuminate.
sit on bike - stand up, hazard light off - is this also a safety cutout for it starting?
Are there any other safety cutouts for starting that i need to be aware of?
The oil light goes on and off occasionally during trying to start - i cant see this being any reason for it to not start tho.
Should i get the plugs out and check them over?
Anything else i should check ?
I would presume there is troubleshooting process - i have one nailed for my scooter to check, but im kinda lost on a 4t bike.
Am i right in thinking there is no neutral light?
Also, is there any online users handbook/overview/pdf's of the bike online?
I know with the Lambretta etc there is a ridiculous amount of literature online, but i cant seem to locate anything easily about the ss.
Again, sorry to ask so many stupid questions. i *really* hate being a newb.
Cy
[Edited on 27-1-2006 by Fiver]
Old 29-Jan-2006, 08:23   #13
Hello Fiver,
You can download some owners and workshop manuals here,www.duc.nu/manuals.
Yep,I know you have a 600 but the 750SS is a very similar bike and the manuals should tell you all you need.
Haynes also do a manual that covers all SS models.(no.3290)You can get them at any decent bike shop or the larger Halfords stores.
AFAIK,the sidestand warning light on a 600SS is just that,...i.e a light warning you the stand is down.I dont think Ducati fitted cut-out switches to that model.
There should be a green neutral light on the dash.(Top left on the idiot light panel,if my memory is correct)
If yours is not working it could be just a blown bulb or a faulty switch.(The switch is in the back of the gearbox,between the engine and swingarm)
Hope this helps.
Old 29-Jan-2006, 11:30   #14
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
The pro fst or carb heaters won't help with the cold starting issue, carb icing occurs when the bike has been running for a short while.
Most likely you just need to get the choke right before pressing the starter. Key on, choke full on, don't touch the throttle at all, press the starter, you should at least have it firing as it turns over!
A good battery charge is essential, and a new set of plugs can make a big difference as well, they're not expensive!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:39.
