Old 03-Feb-2006, 17:49   #11
DSC Member AK AK is offline
AK's Avatar
you cant use avgas for racing - rule book states commercially available for retail (or words to that effect) and i dont think the octane is over 100 for road race (but i could be wrong)
Avgas & similar are not good for your road bike either - we've used it on the drag cars (better to be a top fueller eh?)
but that is when AK (& gang) can strip & rebuild after most runs.
C
Old 03-Feb-2006, 17:52   #12
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
im going to try something revolutionary im going to " twist the throttle " more.....maybe even brake later or EVEN carry more cornerspeed.....
guess u race gods that have ridden to the edge of your abilty are looking now at the weakness in your bike for that extra advantage...........,.....
Old 03-Feb-2006, 17:53   #13
jeff st4s jeff st4s is offline
jeff st4s's Avatar
Mood: Looking for a one way ticket to the 'Ring.
My mate in california nearly fell over when I said I was now using 97 octane not 95, he can struggle to find the minimum required to run his merc. 93.
In texas he says it can go down in to the mid 80's in octane, that why they all run big engines to get power, because the fuel is crap.
Old 03-Feb-2006, 17:53   #14
couchcommando's Avatar
Mood: ooooh
1.5 Fuel
All engines must function on normal unleaded fuel available from normal filling stations open to the general public. The use of any octane boosting or other additives, is strictly forbidden.
Old 03-Feb-2006, 17:54   #15
AK's Avatar
Tesco's is normal enough
Old 03-Feb-2006, 17:54   #16
Mood: ooooh
Why do you have a dynojet kit and race exhausts, it would have been cheaper to twist the throttle " more.....maybe even brake later or EVEN carry more cornerspeed.....
Old 03-Feb-2006, 17:59   #17
dickieducati's Avatar
here we go....fight fight fight.
Old 03-Feb-2006, 18:03   #18
fil2's Avatar
slightly different....but then again i did not expect a moderate reply from a race god............
one day i will attain the dizzy heights of being able to worry about spark plugs and fuel types..till then i will concentrate on my riding.............. :P
In your defence you do need every advantage you can get in this cheap race series............
Old 03-Feb-2006, 18:05   #19
Mood: ooooh
Not slightly different at all, you are asking why carry out mods when you can ride harder ?
By this logic no mods should be allowed until you can ride a standard bike at 100%......there is no one in this series that can ride a bike at 100% so no mods would get done !
Old 04-Feb-2006, 10:48   #20
Monty's Avatar
For those who either a/ can't be bothered or b/ don't understand Shazzam's posting let me make it very simple.
The higher the octain rating the SLOWER the fuel burns-high octain fuel is a waste of time unless you have the compression to make use of it-in fact it will give you lower performance since it won't burn quickly enough. AK's top fueller would be using horrendous compression ratio's hence the need for high octain fuel. My TZ runs on Avgas-but it uses a 16:1 compression ratio............enough said?
Also as has been pointed out Avgas/race fuel/additives etc are specifically excluded from the rules-as long as you can buy it in a standard petrol station-and it's unleaded-that's fine. I put the last bit about being unleaded in since you are not able to buy leaded fuel, or even lead replacement petrol any more apart from a a very few select stations which keep it for 'historic vehicles'.
So avgas will give you no advantage unless you are running really high compression-but then if you were doing that you'd be outside of the rules anyway-catch 22!
John
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:36.
