Old 20-Feb-2006, 10:30   #11
ziggi ziggi is offline
ziggi's Avatar
That sounds just like my problem - I must admit I didn't really hang around before setting off. The previous times I had give the bike a good 5 min warm up before setting off.
It does have Keihin carbs on it, not sure if that would make a difference. How could I tell if it's got a carb heater kit on it? Looking through the paperwork it looks as if the carb heater kit was fitted under warranty at some stage but with a change of carb would this be irrelevant now?
Thanks all for your replies so far.
Old 20-Feb-2006, 17:51   #12
Don't think you can fit carb heater with Keihns (you'd see oil lines going from oil-cooler to carbs), and flatsides are supposed to solve the carb-icing in any case.
Old 22-Feb-2006, 09:30   #13
Bikes: ST4S
Mad Dog Bianchi's Avatar
try giving it a good warm up and see if the problem goes away. Carbs are metal and transmit cold real well to gasoline.....LOL
Old 22-Feb-2006, 09:44   #14
Herb Herb is offline
It does not need to be that cold for carb icing to occur as air will cool to freezing temperatures as it accelerates through the carb. If there is lots of moisture in the air, that will be enough at this time of year to cause icing problems.
Old 22-Feb-2006, 11:45   #15
ziggi's Avatar
And I was giving it some to be honest. I will test again this weekend if it's not snowing.
Old 23-Feb-2006, 09:25   #16
Bikes: ST4S
put on chains and try it in the snow for a real treat!!
Old 25-Feb-2006, 21:41   #17
ziggi's Avatar
Just to let you know that all is great with the superlight now. Neutral light fixed, not a single backfire today and fantastic ride out. She does just over 140 on the speedo and I can even get the front wheel off the floor occationally.
Thanks for all your help
Old 03-Mar-2006, 07:28   #18
Bikes: ST4S
Are you using it instead of weights? Must be great on the biceps!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:07.
