Old 22-Feb-2006, 20:32   #11
duc daz duc daz is offline
duc daz's Avatar
yes it is the 04 model
Old 22-Feb-2006, 20:33   #12
duc daz's Avatar
is there a on going problem with this model
Old 22-Feb-2006, 20:51   #13
999TREV 999TREV is offline
999TREV's Avatar
Mood: Always red
had this problem with my 03 999 as I applied the brake there was a lot of vibration or chatter from the front end and the brake's felt very wooden.
This was bad in the wet as the brakes did'nt work at all at first and then grabed strongly. (nearly cost me my life, out one day when it was wet).
took it to Carl Harrison's in Harleston and he said i had glazed the pads.
Im not a fast rider so this supprised me!!!. However, he was spot on.
hope this helps........ the boys are right, get someone to look at it.
Old 23-Feb-2006, 00:33   #14
Twinfan Twinfan is offline
Twinfan's Avatar
Nope - not that I'm aware of.
Old 23-Feb-2006, 11:06   #15
Twinfan's Avatar
Ducati and Brembo couldn't find a fault with the brakes, but as a goodwill gesture they very kindly repaired the bike for me.
Old 23-Feb-2006, 20:15   #16
duc daz's Avatar
this sounds about right you know
Old 25-Feb-2006, 14:47   #17
nickocaz nickocaz is offline
front brake
i had the same problem on my 749BP 2005 model, took it back to On Yer Bike and they tested it thoroughly on the road and off. Informed me that the front discs were slightly warped and they are changing both discs and pads under warranty. I know what you mean by symptoms it's as if the pads are not gripping the discs properly, slight pulsing/vibes and a weird noise. I will let you know if new discs/pads sorts the issue.
Old 25-Feb-2006, 16:44   #18
khushy khushy is offline
khushy's Avatar
I have had an odd problem with my brakes - 05 999s - that I managed to sort this morning - here is what has happend . . .
new 999s April 05
Original MC retained - mated to my Monoblocs
throught the 05 riding season (6000 miles) no problems
bike laid up for 6 weeks in Nov
calipers serviced
brakes start to bind when remounted on the bike
bike serviced - brakes still binding
calipers serviced again - then replaced on bike
still binding
stripped the whole front brake system, new washers, new fluid etc this morning and re-bled thoroughly incl special attention to the MC
still binding
thought that it might be the pads
when I applied the MC - I quickly undid the top banjo to see if this releases the pressure - no luck
bled once more - calipers & MC with new fluid - SORTED!!!
no binding - wheel runs freely
I am guessing that there is either a fault with the MC - it didnt seem to be releasing the pressure in the system or it was all down to a bubble!!
Never ever had this problem before - weird or what???
My best guess is a tiny tiny air bubble in the MC at the very top of the brake system.
Khushy
[Edited on 25-2-2006 by khushy]
Old 25-Feb-2006, 17:18   #19
duc daz's Avatar
ive took it into JHP COVENTRY and told them about the problem .Hope they can sort out the problem .
Old 26-Feb-2006, 02:41   #20
bike mad bike mad is offline
bike mad's Avatar
I took my 999 out the other day and the brakes were binding, after a good look I striped the brake callipers of the bike and found my problem, the brake pads had rusted to the callipers.
a quick rub with a brass brush ect and a tooth pick to put a small amount of copper slip on the touching surfaces and there better than new,
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:46.
