Old 26-Feb-2006, 14:25   #11
Like Rockhopper says, you have to cut the clock casings open.
Use a hacksaw blade (junior) and cut around the full perimter of the clock bezel, about 10mm below the glass. You need to get this as straight and square as possible as you've got to glue the bezel back together along this line.
you have only got to cut the plastic. Go too deep and you'll cut into the clock mechanisms.
Once the you've cut the clocks open, remove the needles, noting their positions and swap the faces over.
Then you need to replace the needles, exactly as if you get it wrong they will read wrong, and then glue the bezel back together with PVC glue or such like. Wrap the joint in black insulation tape as neatly as possible to seal the joint. If it doesn't seal, you'll get condensation inside the glass.
I've done two sets. Took about 3 hours..........................
It's doable, but it's a lot of fiddly work. You've really got to want to this
If you want a set of yellow ones, i've got some. Bought them for my own bike and have never fitted them.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:29.
