Old 14-Mar-2006, 16:44   #11
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
the 620 clutch cover is the same than the latest 600, and I think there should be 13 bolts not 10...
Then a rubber hammer and you're done.
Old 14-Mar-2006, 18:30   #12
domski's Avatar
Let your team technicians do it
Old 14-Mar-2006, 18:50   #13
butch890 butch890 is offline
Mood: Enjoying Togdom !
Originally posted by khushy
if you only want to check the plates - surely you only need to take off the clutch cover and NOT the housing???
khushy
Its a 620 WET clutch not a 900/996 type
Butch
Old 14-Mar-2006, 19:49   #14
Founder Member
Paul James's Avatar
[/quote]
Butch [/quote]
You out and about again then ?? Hope the move went well. Did you see my reply to your post on the stickers thread ? Still no U2U or email so not sure if you are still having email probs ??.
Old 15-Mar-2006, 13:29   #15
GlennG GlennG is offline
Mood: accepting the inevitable
Thanks for the ideas guys, you were right Tim - if in doubt get a bigger hammer ... last night I managed to borrow a big hide mallet and that did the trick after a few whacks around the cover (it was explained to me that the rubber mallet 'bounces' off the case, whereas the hide mallet almost 'stops dead' on contact with the case and so passes the force onto the case instead of kicking back), case was held on with threebond type stuff (no paper gasket). Checked all the all the plates and they were fine and the basket had no groves in it as well, so no problems there. Off to Baines later to pickup a paper gasket to make it easier in future. As for the unusal clutch noise I think I need to compare mine to others at the same time, in case I'm being paranoid
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:36.
