Old 16-Mar-2006, 00:27   #11
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Cheers Paul, but I'm not trying anything on Alan's fork, I really must find another pair if I want to race at Cadwell.
Well, I've already been ridiculous trying to fit my front brake: I was beaten by a pair of forks.
Nevermind, I'm not sure the front brake is needed to have a bike Dyno'd (that's not an MOT...), let's try to fit the rear one
Let's say I've been even more ridiculous: after having poured 3/4 of the DOT can through the reservoir, there is still no way it will stop my rear wheel
I was sure to be following the good procedure: fill in the reservoir, pump, pump, pump and hold it, undo the drain bolt, look at the pipe, do the bolt back. Check liquid level in the reservoir, pump, pump, pump again, etc...
I give up.
I will race without brakes.
Old 16-Mar-2006, 00:28   #12
Tonio600's Avatar
Message original : phoenix n max
If in doubt - hit it - hmmmm. Hey Tonio have you removed the socket in the wheel spindle yet ? - Finally got ours out last week thanks to gas cooker and loads of WD
Yep, got it a long time ago, kick in the fork and it went
Old 16-Mar-2006, 01:00   #13
domski's Avatar
I give up.
Boy am I glad I'm not in your race!!!
Old 16-Mar-2006, 01:12   #14
same problem I had last year at Cadwell which caused me to crash in one race and pull out of the other two.
Fixed by recessing the fork bush futher by taking a stepped cutter to the fork leg, I also made up a slightky narrower speedo replacement spacer just in case but didn't use it.
Deatils in last years DD diary
http://217.199.188.40/xmb/viewthread...5043#pid216513
Old 16-Mar-2006, 09:00   #15
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
Originally posted by twpd
Wheel spacers? Done it myself recently when I was tired and working late. Easily done.
Same here when fiting the twin disc setup.
Old 16-Mar-2006, 09:09   #16
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Hope you're OK, didn't end up on your Assen, and that the forks didn't get away with it.
Old 16-Mar-2006, 09:58   #17
Tonio600's Avatar
Message original : phillc
I'm sure those forks are trapped... It's a try to put me aside of the races... Well done Knight RR team, that's tricky
Old 17-Mar-2006, 08:39   #18
Grib Grib is offline
Grib's Avatar
Mood: Ducati-less!
I think you should put the spanners down and step away from the motorcycle!
Old 17-Mar-2006, 09:19   #19
psychlist's Avatar
Mood: Lucky? For some, maybe!
....I will race without brakes.
Yep! Sounds about normal for 583's
Old 17-Mar-2006, 09:45   #20
Tonio600's Avatar
Message original : Grib
So who's gonna do it???
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:09.
