Old 21-Mar-2006, 01:10   #11
Maxypriest Maxypriest is offline
Mood: Fed up I'm not racing. :-(
I noticed this on mine! I thought that one leg was bu&&ered, but thought that it didn't really matter... sort of ish. PS i'm using 2.5W. Like water it is.
Old 21-Mar-2006, 08:10   #12
Grib Grib is offline
Grib's Avatar
Mood: Ducati-less!
Our RS250 has damping in one fork....we changed it to have the later, 'proper' forks....made sod all difference
Old 21-Mar-2006, 18:05   #13
phil_h phil_h is offline
phil_h's Avatar
Latest news from Maxton
- they _can_ supply custom cartridges for 360+vat + labour
....... with 4-5 weeks lead time.
More importantly ...
they have found that there are all the variations that we have wondered about fitted by ducati over the years ...
spring only on one side + damping only on the other
springs both sides + damping only on one side
or rebound one side + compression the other
So this is yet another chapter in the book of 'how crap is the 600 spec'
Oh - and the other thing that they have found is that the std fork seals are really tight and give bad stiction - making their cartridges seem as if they arnt working properly on a road bike. (not so bad on a race bike cos its worked harder)
They cant fit alternative seals cos they are a ******* (correct use of technical term !) size, so they tried 'easing' them a bit and that worked until they leaked after about 500 miles ! (qed)
[Edited on 21-3-2006 by phil_h]
Old 21-Mar-2006, 18:10   #14
paynep's Avatar
Mood: Wet wet wet
Bloody glad all my bikes have Showas!
I will delve into my Marzochistis and see what's inside tonight....
Old 21-Mar-2006, 23:51   #15
paynep's Avatar
Mood: Wet wet wet
Interesting.....
Both legs have dampers, each leg had the spring the opposite way up, the non-leaking leg had about 2 teaspoons of oil in it....
Anyway, now both legs are non-leaking, have 7.5w oil in to the correct level and appear to offer a modicum of damping....
Lucky me, eh
Old 22-Mar-2006, 00:06   #16
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I'm surprised they didn't mention a well-known little trick to ease stiction. You take some fine-grade wet & dry to the stanchion and gently crosshatch using a rotating up/down movement. This promotes a very very impeceptible oil loss which, keep the legs and seal lubricated. I did this to great effect on my SV650 racer.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:35.
