Old 26-Mar-2006, 22:25   #11
Ducati Dealer
wilf's Avatar
erm... lunchtimes, evenings and every spare weekend in winter, Steve did the really technical stuff.
Good point about the swingarm nelly, 54mm is the biggest you can get in there, but it does fit, with a bit of fiddling.
Motor is not quite finished yet, but should be together in a week or so. After its been on the dyno and i'll post the results.
Old 26-Mar-2006, 22:29   #12
Ducati Dealer
wilf's Avatar
Chassis isnt quite finished either...
Old 26-Mar-2006, 22:42   #13
cl0nd0n cl0nd0n is offline
cl0nd0n's Avatar
Originally posted by raykay748R
Just a guess, but probably in his lunch times at................................... ?Check the site on his thread!!!
Ooops. Foot in mouth and all that!
You learn something new everyday!
Old 26-Mar-2006, 22:43   #14
cl0nd0n's Avatar
Cheers Wilf. I look forward to seeing the results!
Frame looks awesome!
Old 26-Mar-2006, 22:46   #15
Mr_S Mr_S is offline
Blue's a bit girly though
Wilf, I see you're still leaving things to the last minute as usual...
Old 26-Mar-2006, 23:11   #16
Ducati Dealer
wilf's Avatar
Mr_S
you, me, cadwell, now!!!
i'll have you know that's 'Purple Sparkle"! chose it myself.
plenty of time yet, not booked on track until the 2nd week of april!
Old 26-Mar-2006, 23:22   #17
Best pull your finger out then
May drop in a see you guys tomorrow as I haven't had a chance to call in for a month or so and I'm in Basingstoke bright and early!!!
Old 27-Mar-2006, 10:17   #18
cl0nd0n's Avatar
853 kit on its own, i.e. not done as part of a service, is about £1200 fitted/set up, inc gaskets, dyno runs etc. etc. if you dont have an adjustable chip (FIM Ultimap) or power commander then you'll need one too.
IMO, 853R is a mega conversion, i love em! the peak horsepower figure is only up by 5-8 bhp usually, but the area under the graph is much better, more mid range, typically the power you get at 10k on the 748 you get at 8k on the 853 and it holds it until 10k, so when you change up you don't get so much of a power drop, it feels great to ride. The revy 748 but with more punch out of corners.
748 R is the best model for the conversion but you need to use high compression pistons, the 748 R pistons have large crowns and the valves are set back in the head to suit (748R has a larger cylinder head volume than the other 748 models) Increasing the bore size increases the compression ratio anyway but with flat top pistons you would lose out on a lot.
Wilf
What sort of power do you expect to have top end on the 853R? I am guessing top end speed is swapped for grunt lower down the range.
Sigma reckon the are seeing about 118bhp from the 853R.
Any ideas if this can be improved on?
Old 27-Mar-2006, 10:24   #19
cl0nd0n's Avatar
Just found this . . . .
Sigma reckon 136mph from the 853R. That does seem a little slow when you compare it to some of the equivalent Jap bikes!
Old 27-Mar-2006, 11:38   #20
That last graph is through the gears. There's only 5 "peaks" so I guess they thought the dyno had had enough at 140mph, and didn't run it through top
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:09.
