Old 31-Mar-2006, 23:21   #11
sheeny748 sheeny748 is offline
screw some bolts back into the threads in the sprocket. attatch two pairs of mole grips to the bolts and pull. should come off no problem!unless the splines are worn and somebody has welded the old sprocket on?
Old 01-Apr-2006, 10:27   #12
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
Let's hope not, but the evidence of that would be obvious from the front. I would guess that it just needs some gentle persuasion and a liberal dose of penetrating fluid. Good luck
Old 01-Apr-2006, 12:39   #13
Duke2BSteve Duke2BSteve is offline
Duke2BSteve's Avatar
You might find that overtime the heat generated is causing it to stay on. I had this problem on one of my older bikes. I just gave it several large taps with a wooden mallet (or a hammer and a wooden block).
Also direct heat from a flame torch usually shifts it...
Old 01-Apr-2006, 18:49   #14
loverobot's Avatar
tried a bearing puller and will not budge
is it possible for the thing to turmn slightly on the shaft as the holes dont look to line up exactly?
Old 01-Apr-2006, 20:07   #15
Ducatis generally have a problem keeping the sprocket on the shaft not the other way around!
Are you sure someone hasn't stuck a blob of weld on the back of it?
Old 01-Apr-2006, 20:51   #16
loverobot's Avatar
not that i can see
am giving up
dont want to wreck the shaft
will have ducati john have a look next time i am over
Old 02-Apr-2006, 12:36   #17
moto748 moto748 is offline
loverobot>
When you say "the holes dont look to line up exactly" I take it you mean the tapped holes in the sprocket and the holes in the retaining plate if you offer it up.
That's the point of the groove with no splines on it on the shaft. Can you see the groove in front of the sprocket? The retaining plate sits in the groove, and it has to be rotated a little in the groove so that it lines up with the tapped holes in the sprocket (this is on re-assembly, if you see what I mean). if these holes weren't offset, there'd be nothing to stop plate and sprocket sliding along the shaft, past the groove, until it started rubbing on the grey plastic cover.
But presumably if you've taken the plate off, you know this already?
My guess'd be that the splines are clogged up with gunge.
Old 02-Apr-2006, 20:42   #18
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello loverobot
maybe a stupid question, but how many teeth are on the sprocket.
regards
TopiToo
Old 02-Apr-2006, 21:09   #19
loverobot's Avatar
the sporcket plate was off and i mean it looks like the splines have shifted?
anyway plate back on and will get john to have a looksee
now i have a chain question - see my other thread lol
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:58.
