Old 03-Apr-2006, 19:20   #11
Mood: wobbly !!!
Not heard of that as a problem on Ducs, and as its only ali wouldnt it torque out.
Still need Help
Kev
Old 03-Apr-2006, 20:10   #12
Zimbo Zimbo is offline
Zimbo's Avatar
Mood: fair to middling
Did you make sure the small dowel was still in place ? Did you smear any liquid gasket on the o-rings before assembly? And clean off any old stuff?
Is the compression still good?
Old 03-Apr-2006, 20:37   #13
Screwy Screwy is offline
Screwy's Avatar
Probably of no help as I have never had the head of a belt 900 Duke but it sounds very like the bevel duke in construction , Is it possible one of the O rings has moved , been displaced on re-assembly and has been nipped between the head and barrel ? This happened on my old Darmah and caused a leak very much like the one you describe .
Old 03-Apr-2006, 23:32   #14
Mood: wobbly !!!
Zimbo it all came away clean with no sealant of any kind present, so it just needed a little clean up with brake cleaner and put it back together clean. Is there supposed to be anything on the faces or the O rings ?
Scewy it looks like its coming apart again to make sure, but I dont think the rings would move during assembley as they were a good fit in the recesses.
Anyone done this and had complete success, Am I just un lucky
Old 03-Apr-2006, 23:45   #15
monstermob 998's Avatar
Kev - i take it you did use the green 'silicon' rings? not replace them with black rubber ones? dumb question i know - the green ones withstand higher pressure than the black ones
having just replaced the vertical head on my SS you havent instilled me much confidence but havent had a problem haveing the heads off three times now- i hold the rings in with a smear of grease when placing the head onto the barrell
[Edited on 3-4-2006 by monstermob 998]
Old 04-Apr-2006, 00:01   #16
Mood: wobbly !!!
Yeh they are new ones from Snells. Only cheap, thats what makes it worse.
Have you run yours yet ?
Old 04-Apr-2006, 00:08   #17
Take her to Nelly ya tight git!!!
Old 04-Apr-2006, 00:15   #18
no.havent run it yet....... i havent had time(too much work)plus i keep finding things i want to change such as adding the carb warmers thats been sat on the shelf -adding all stainless bolts- and new clutch plates to get the bike all back together still got to do electrics and exhaust-- but havent had a problem in the past with oil leaks-- got mine from snells and moto rapido --snells only had the small one in stock - they said some geezer with a 900 had the last two big ones!!!!!!!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:38.
