Old 03-Apr-2006, 22:23   #11
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
oh, one more thing please:
i want to replace the nasty old springs and collars at the same time. it seems a shame to spoil the looks of the gold pressure plate that was fitted by a previous owner. there are some nice looking spring/collar sets on ebay http://cgi.ebay.co.uk/Ducati-dry-Clu...cmdZV iewItem
i've bought dzus clips and stickers etc from these guys before, and their service was excellent, but obviously, with these being a mechanical moving part, i'd like to know if they're up to spec before buying.
any thoughts?
Old 03-Apr-2006, 22:30   #12
Dibble
buy the springs and caps from Nelly, he has them on the shelf ....
best way to get the plates out is a couple of those magnetic telscopic pen thingies (technical term that) ...
Old 04-Apr-2006, 11:22   #13
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
open out a large split pin and bend the end slightly to make a right angle, hook them out with that
Old 04-Apr-2006, 13:32   #14
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
Ditto, or thin gauge welding rod, anything that'll create a strong pair of hooks. Good luck
Old 04-Apr-2006, 19:23   #15
zhed44's Avatar
Mood: YELLOW!!!
thanks for all the advice once again.
was out on the 748 again today and the benefits of the strip and clean have already worn off - i was half way past a car when it started to slip - so i was riding alongside them, more or less at the same pace with the engine wailing away, all about 2 feet from their side window! i felt quite sorry for the driver as they must have wondered why this black clad, black visored nutcase on a black motorcycle with open pipes was riding in formation with them absolutely revving the nuts off his bike!
anyway - ST4s clutch and spring kit on order from nelly.
thanks again for all your help.
[Edited on 4-4-2006 by zhed44]
Old 09-Apr-2006, 21:37   #16
zhed44's Avatar
Mood: YELLOW!!!
Got the new clutch pack fitted today.
As is always the case with me, it didn't go without a hitch though.
After I had finished, I went to test it - mmmmmm, that's odd, it'll go into gear, but not back into neutral even though the light is showing, then the clutch lever went really stiff, then I couldn't budge the gear lever. Mmmmmmm.
So - I thought I'd better whip the cover off and have a look what was going on - only to have the answer dawn on me as I saw the scraped tops of my lovely new red spring caps and the track they had worn on the inside of the cover. How come?
As I was finishing up (the first time round) I noticed that the clutch cover gasket was a bit knackered, so I thought "I won't bother with that in case any straggly bits get caught up in the springs" - as a result, there wasn't enough clearance between the springs and the inside face of the cover Has now been refitted.
Anyway - is all working well now.
Thanks to Cornerspeed for the fast delivery and the idiot proof instructions, and thanks also for the advice and tips from you guys - the magnetic picker-upper-thingy was a masterstroke - I had the old plates out in 10 seconds rather than 10 minutes.
Final question: I found that there was only 1 thick plate instead of 2 in the bottom of the old clutch pack - why would this be? I have fitted 2 this time. Also, the bottom of the basket had what at first I thought was a weld repair, but on closer examination seems to be a thin streak of molten, solidified metal. Surely someone hasn't melted a clutch plate at some point in this bike's chequered past?
Thanks again
[Edited on 9-4-2006 by zhed44]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:55.
