Old 07-Apr-2006, 21:30   #11
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Doh,
I just realised something.
The attached Dyno chart shows the trace for an intermediate run at 126hp (the red trace on the original).
There are 2 other traces on the chart, yellow and pink (132) but they are not visible at all on the scanned version I received. I'll copy and post up the originals when I get them in the mail from Chris.
Spin
Old 07-Apr-2006, 21:33   #12
Originally posted by spinoli1
After discussion with Chris I decided to go for the following –
· CJS Super Set-Up (basically a blue-print for everything above the cases)
· Full cylinder head porting
· Skim heads for increased compression (12.4 to 1)
· Set squish
· Cam Timing to CJS figures (previously set to Ducati figures when the cams were installed)
· Custom Mapping for PC111USB
At £350 that sounds like excellent value
Old 08-Apr-2006, 00:37   #13
deej deej is offline
deej's Avatar
and all done in a very professional manner too kev
just dont take him up cheese and onion crisps
Old 08-Apr-2006, 09:38   #14
weeksy2 weeksy2 is offline
Hmmmmmmm will be having a chat with Louigi when i go down after the GP..
nice write up fella.
Old 08-Apr-2006, 12:20   #15
Bikes: 998Bip
Mood: Carbonara
Skidlids,
The Super Set-Up is £350.
This includes:
Cam dial
Heads off
Valve gaps
Valve seats
clean pistons
hone bores
ring end gap setting
squish
TPS set-up
Throttle body balance
and other stuff - Chris will give you the full run down
Chris issues a certificate after the work has been done.
Doesn't include the porting/PC111 mapping etc, but it's still great value.
If you have the porting done at the same time, the additional cost is very reasonable.
Spin
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:23.
