General Motorcycles only
Old 24-Apr-2006, 21:26   #11
Phil_Superlight Phil_Superlight is offline
Originally posted by AL900SL
Daft thought, but is there anything loose in the air box and blocking the intake on one of the carbs.
Hi bud they seem fine as i was looking at them yesterday when i had the filter out as the bike wouldnt start with it in but run fine when the filter was replaced.
Old 24-Apr-2006, 21:39   #12
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
Originally posted by raykay748R
Do you still need choke all time??
Are the carb bowls filled with fuel when the engine has died??
Still need answers to these b4 we move on to the ignition side and the only reason I'm pushing on these is because your initial problems were obviously fuel related.
Check sparks at plugs anyway.
Old 24-Apr-2006, 21:50   #13
When the prob first started it wouldnt start unless i used the choke but on other times like when i removed the air filter it started without the choke. How do i check if the carb bowls have fuel in?
Old 25-Apr-2006, 09:53   #14
Hmmm....you can take the drain plug out of one of the carbs - but I'd turn the fuel off first under the tank. Just put some rags under the carbs to catch the fuel.
I wonder if you have had water in the tank and its now in the carbs?
Is this all something that happened suddenly or has it been getting progressively worse??
Good luck - Frank
Old 25-Apr-2006, 20:22   #15
Hi frank it happened straight away as in one day it was fine the next it wasnt, il try that with the carbs and see if it helps any
Phil.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:45.
