Old 06-May-2006, 22:54   #11
Felix Felix is offline
Since you say more performance as opposed to power, I'd definitely get the suspension sorted first. K-tech and Maxton are two very good starting points. It will transform your bike. Do that first, ride it, and see what needs doing next (probably the brakes).
Old 06-May-2006, 23:07   #12
Red-Duc Red-Duc is offline
Red-Duc's Avatar
well thanks for all the advice, you have given me plenty of things to think about and look into, I think the more expensive options will have to wait till next year
Old 07-May-2006, 09:22   #13
Ian900SLV Ian900SLV is offline
Mood: All SP'ed up at the moment
Changing the gearing is a good cheap mod, I raised my rear sprocket size by 2 teeth and it transformed the bike, this really does give you the feeliing of better low down pull but does drop your top speed a little. I have a bora conversion on my standard cans and have just fitted a ducati performance filter and lid kit. This has made the bike breath a little better (The intake roar on full throttle is superb) Just got to fit the jet kit now, hopefully this will iron out a small flat spot i have around 6k when throttle is wide open.
Have fun
Ian
Old 07-May-2006, 16:56   #14
Ains. Ains. is offline
Ains.'s Avatar
Mood: He's not happy {:o( He's back at sea!
Spend the dosh on a suspension set up for you on the bike as mentioned above and then get yourself on a riders school on a track.
The day you sail round the outside of a GSXR or similar who then asks you what you've done to the bike; the answer being nothing mate, it's dead bog standard apart from the suspension's been set up.
Kin yes mate. Grin factor high!
Ains.
Old 07-May-2006, 22:45   #15
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Ains.
My mate does that on his harley with modified ( extended ) forks and 3 foot apehangers. They never ask him what he's done to the bike because they've gone into a state of absoloute shock
Old 08-May-2006, 15:54   #16
Red-Duc's Avatar
Can anyone tell me what comes with a dyno jet kit and are they easy to set up
Old 08-May-2006, 17:17   #17
keefer keefer is offline
keefer's Avatar
jets
needles
springs
as mentioned above
take off the carbs
swap the bits over
go for a ride
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:07.
