Old 14-May-2006, 20:24   #11
Trig Trig is offline
Bikes: Ducati 999, BSA A65 Lightning, Matchless G80s
Trig's Avatar
Mood: Fed up with DIY!
Hopefully it is now sorted and this info can help someone else with the same or similar problem.
I removed the battery, followed by the 3 screws (2 at the top and 1 in the base of the battery housing) that release the plastic moulding that houses the battery.
A couple of cables were cable tied to the fan housing. After releasing the cable tie the whole assembly nearest the front wheel can be gently pulled away from the bike. At this point I was expecting to be able to see the relay sitting in what I think was its original housing (see the top circle in the picture). But it is empty and I needed to dig a bit deeper. You can now get to the heat shield at the back of the assembly. This needs to be removed and is held in place by 4 cross head self tapping screws. You can see it lieing to the left hand side of the picture.
The fuel pump/ignition relay is positioned at the bottom left hand corner at the back of the assembly. Shown removed in the bottom circle.
Old 15-May-2006, 05:55   #12
Cant see the pic.
Old 15-May-2006, 09:40   #13
Trig's Avatar
Picture 1
Board wasn't working right for me last night. I will try again!
Old 15-May-2006, 09:56   #14
Trig's Avatar
Picture 2
Thats better
After diconnecting the relay I could see that water had been getting in from the white crud around the contacts (picture 2).
I cleaned up the terminals with wet and dry. Then put the relay back together using a thin smear of Blue Hylomar on the edge of the mating face and left it a while to 'go off'. Then I wraped some insulating tape round the joint for good measure and reassembled.
Remember to connect the positive cable to the battery first.
I will let you know if the problem is fixed. Please let me know if I have cocked up on any of this
Old 15-May-2006, 09:58   #15
Trig's Avatar
Picture 2
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:50.
