Old 27-Sep-2003, 14:35   #11
Triple Nine Triple Nine is offline
Mood: Very happy with the Multi
Originally posted by Jon
What about the air at 36 psi,
What about Helium
Old 29-Sep-2003, 08:25   #12
jodycraw jodycraw is offline
Mood: good
i remember from school that compressed helium weighs more than compressed air anyway....
Old 29-Sep-2003, 08:30   #13
Totto Totto is offline
Is it not something to do with Helium being less heat sensitive !
Old 29-Sep-2003, 18:51   #14
DJ Tera DJ Tera is offline
why do balloons filled with helium rise then?
Old 29-Sep-2003, 21:58   #15
The air in a tyre will weigh about seven times more than helium in the same tyre at the same pressure and temperature.
Old 07-Oct-2003, 14:30   #16
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Attn Shazaam
It look like you have access to some data and I was wondering if yoy knew how much the 3 spoke Brembos weighed in at.
When you list the weight of the OEM 5 spokes I assume these are the as delivered items (as opposed to the forged items) that first appeared on the 2000 SPS and now grace everything including Monsters and STs?
Thanks,
Rob
Old 07-Oct-2003, 17:06   #17
Marchesini magnesium 5-spoke ... 6.8 lbs ... 8.7 lbs. rear
Ducati OEM aluminum 5-spoke ... 9.3 lbs ... 12.0 lbs. rear
Ducati OEM aluminum 3-spoke ... 11.5 lbs ... 13.3 lbs. rear
Ducati lightened the wheels in 1999 compared to prior years. I don't know how much, but they said so in their '99 brochures. Could be just a few grams.
Old 07-Oct-2003, 18:22   #18
Rob B's Avatar
Wow, so if I had the dosh, changing the Ally 3 spokes (with Dunlops) on my 888 for the new Marchesini Mag 10 spokes (with Bridgestones) would be like halving the current wheel mass. Wow.
Thanks.
Old 20-Mar-2004, 11:45   #19
DSC Member Duncan Disorderly Duncan Disorderly is offline
Mood: Life is not a rehearsal.
Y shaped 5 spoke
Hi
When you talk about the Marchesini 5 spoke are you referring to the new Y shaped in light alloy that come on the 999/749s?
If not does any one know the weight of these to work out if its worth changing for magnesiums?
Peter
Old 20-Mar-2004, 17:59   #20
Mike Davis Mike Davis is offline
Mood: Shiney
TOTTO NO
Your thinking of Nitrogen mate.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:55.
