Old 15-Jun-2006, 16:50   #11
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
You can re-use copper washers if you anneal them first. Heat them to cherry red and plunge into cold water. Better to replace aluminium ones though.
Old 15-Jun-2006, 19:08   #12
phil_h phil_h is offline
phil_h's Avatar
I re-use both copper and aluminium sealing washers on a variety of engines.
Its the flatness of the sealing surface that matters not the age
If you are doing it for a living, or not able to check them - ie if in doubt or in need of reduced hassle factors, then obviously the safe option is to replace but its not mandatory.
Oh - and why am I qualified to make a comment ?
Well, if you could see my signature, you could see that I race bikes that are 35 to 45 years old, but still oil-tight
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:02.
