Old 15-Jun-2006, 13:58   #11
desmobob desmobob is offline
desmobob's Avatar
Mood: Beige.....
Old rocker issue - interesting.
Interesting bit about half way down, describing the theory of why your rockers aren't as well protected as Ducati may have first thought.
http://www.sigmaperformance.com/rockers.html
My friends shop have known to get them re-chromed, it works out cheaper and often if done by a reputable company can increase life of the Original, replacement ones.
Here's one guy, (appears to be in the U.S) - who's done just that.
http://www.ducatitech.com/4v/maint/rockers/index.html
Interesting pic's.
Old 15-Jun-2006, 16:52   #12
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
Has anyone worked out why the 851 & 888's don't eat their rockers anywhere near as nad as on the later engines? They should suffer from the same oil starvation at start up and (one would assume) be just as sensitive to poorly adjusted valves? Surely if it was just down to bad chroming then Ducati would have got it sorted quickly.
Keith
Old 15-Jun-2006, 18:14   #13
doogalman's Avatar
Arn't the steep ramp angles to blame. The valve gear has to work hard to get the power that we yearn for.
Old 15-Jun-2006, 19:30   #14
hogfisch hogfisch is offline
Mood: dooM
I had mine replated (2 were gone). According to Dave Woods Racing (www.bike26.com) the replating is a longer lasting solution as it is carried out to a higher quality than the factory plating. Still cost 110 quid though
Old 15-Jun-2006, 19:44   #15
crust crust is offline
Mood: :( broken
Has anyone got any experience of these?
http://www.electraeon.com/main.html
seems like a lasting solution to the problem, unless they wear out the camshaft instead
Old 16-Jun-2006, 08:58   #16
james81273 james81273 is offline
james81273's Avatar
Mood: twitching
recommended by sigma performance
http://www.mbpducati.ca/can/shop/pro...roducts_id=233
Old 16-Jun-2006, 09:23   #17
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello
some good links there . . . .
may well look into this further
TopiToo
Old 16-Jun-2006, 12:26   #18
CipiVTS CipiVTS is offline
CipiVTS's Avatar
From what i know, Ducati outsourced the production of rockers in 95-96(?) and because of the financial problems they had at that time, they probably chose a cheap producer.
I opened my 916 a few days ago (4000km since the last service) and found only 1 closing rocker on the admission of the vertical cylinder. The rest are fine. I replace it with a 748 one (2000 model) which seem to be of a higher quality... but who knows?
I'm sure that after market ones are a very good options and if i recall Sigma says they last at least 50k miles!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:47.
