Old 14-Jul-2006, 10:51   #11
had similar problem with tyre not cleraing hugger but that was defo hub positioning....it was at 7 oclock not 4 oclock...just chnaged from 180 to 190 so I'll have a look later, might explain why I'm so slow of the tyres rubbing
Old 14-Jul-2006, 11:38   #12
Are you running a full 998S exhaust, or 998S downpipes with a different link pipe and cans
Old 14-Jul-2006, 15:09   #13
Bungi Bungi is offline
running a full 50mm Termi system kev
Old 15-Jul-2006, 08:44   #14
What tyres are you running???? if it is a Dunlop then you will find that it grows when hot and used at speed due to the profile of the tyre & it will rub the exhaust even a 45mm system, try a differant tyre & see how you get on.
Old 15-Jul-2006, 13:58   #15
Originally Posted by Bungi
so what ive found out is...
that tyres have differing profiles(or should i say shapes )dispite what is written on the side of them,
the dunlop 209s that i was running have a profile which runs closer than say a supercorsa.
come to think of it i had a prob b4 when running a 208 and it started rubbing the rear hugger, just the tyre wasnt on there long enough to cause an issue
as i said chris
Old 15-Jul-2006, 18:50   #16
as i said chris
Ooops, missed that, i would say that your problem lies in the tyres then.
Old 16-Jul-2006, 13:44   #17
DEMON DEMON is offline
DEMON's Avatar
Mood: on the back wheel !!
you mentioned that it had a swing arm from a 748r, what bike have you fitted this to in your original post ?
Old 16-Jul-2006, 23:38   #18
the doner bike was a 748r i took the engine out and fitted a 998s engine.
i used the 520 chainodf the 748r. now running 14-37 sprokets so as it clears.
Old 16-Jul-2006, 23:47   #19
DEMON's Avatar
Question
I remember reading somewhere about differing lengths of swing arms on some of the ducatis. Not much in it, only mm, prob enough to make a difference. I also recall that the exhausts were different too on the 748r...ill see if i can dig out the info from my library at home.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:33.
