Old 13-Jul-2006, 15:26   #11
paynep's Avatar
Mood: Wet wet wet
As I recall, when I looked at it, the pivot seemed to be central vertically and measured the same from all pivots as the std non-adjustable one....
If you want I'll try and get up in the loft tonight and re-check?
But when I fit it, it will be in conjunction with setting the sag, pre-load and getting the steering-head angle correct, so g8d only knows what the actual setting will be....
If all the above isn't done then all it is is a bit of pointless bling..........IMHO of course
Old 13-Jul-2006, 15:36   #12
Jasper Jasper is offline
Jasper's Avatar
I have reset it back to the 3 o'clock position and i am far happier on the bike.It doesn't turn as quick,but feels alot more stable in slower corners.I'm not a racer and don't need racer type ultra quick turning.Paynep,i would still like to know where yours is set ,if it's not too much hassle.
Old 13-Jul-2006, 21:15   #13
paynep's Avatar
Mood: Wet wet wet
Mine has the pivot adjacent to the locating bolt, or 5 notches clockwise from your pic. Like I said, I'm pretty sure that this gave the same dimensions as the std linkage, but I stand to be corrected.......
HTH Paul
Maybe I'll bung mine on to see how it feels and how the sag etc measures up, but I was saving it for the winter when its all going to be in bits anyway.....
Old 13-Jul-2006, 21:43   #14
Jasper's Avatar
That position is where i had move it to.That is as radical as it gets.I didn't like it,too quick turning for me.Of course it depends on how much ride height you have on the u-loop as well!!
Old 14-Jul-2006, 08:35   #15
851neil 851neil is offline
Mood: need a bike...
Jasper, rotate your's by one click anti-clockwise and that's where mine is sitting. Pm'd you about reference pics, bottom of steer tube to centre of front wheel spindle is 475mm.
cheers
Neil
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:34.
