Old 09-Aug-2006, 20:41   #11
DSC Member Karl Karl is offline
Karl's Avatar
Yes used a Dremel tool to make them.
Old 19-Aug-2006, 22:24   #12
polarexpress polarexpress is offline
polarexpress's Avatar
Mood: Impatiently awaiting parts!
I've got 3 brackets that are supposed to fix the belly pan to the bike so that I can remove the side panels without taking the belly pan off.
From this thread I've learned where 2 of them go but can any one of you tell me where the third one goes. I suspect it's up front somewhere.
Thanks!
Old 19-Aug-2006, 22:28   #13
Thanks!
You mean there's another bracket, couple of my bikes only have the two at the back
Any chance of a pic of the third bracket
Old 20-Aug-2006, 10:23   #14
Yes, the set of brackets I bought contains 3 brackets and I suspect one of them goes up front but I'm not sure.
I believe the bracket on the left and right in the picture are the ones that mount on each side of the engine (rear end of the belly pan).
I don't have a clue about the one in the middle, though.
It would make sense if it mounts to the front of the belly pan, wouldn't it?
If not, how do you make sure the belly pan stays in place when you remove the two side fairings?
Old 20-Aug-2006, 11:29   #15
Felix Felix is offline
Yes, there is a bracket on the nose of the belly pan. I'll try to post a pic of how it all fits. It will then allow you to leave the belly pan in place with the side panels removed.
Old 20-Aug-2006, 13:12   #16
Bracket on left of Pic fits rear rigtht of belly pan as it mounts off the two screws that bolt the rear mastercylinder on. The bracket in the middle fits to the rear left of the bellypan using a 10mm bolt and uses the threaded hole in the crankcases just rearward of where the sidestand bolts on, Bracket on right of pic must be for the front of the bellypan but as I haven't seen one before I have no idea where it fits.
Old 22-Aug-2006, 22:39   #17
Bump. I'd love to see those pictures, Felix
Old 05-Sep-2006, 08:30   #18
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
The front belly pan bracket has a Dzus fastener that goes throught the V piece, where it steps in for the mesh vent hole.
See this http://www.mad-ducati.com/GallerySho...2&GalleryId=42
By the way, where can I got hold of a similar belly pan for my track bike?
Old 05-Sep-2006, 10:23   #19
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
I've got one + the v piece, I'm going to fix it a a bit if your interested.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:04.
