Old 23-Aug-2006, 21:36   #11
DaveB916
Had similar issues before on a 900SS was an HT cable breaking down under load, finally traced it by spraying water onto leads via a greenfly killer in the garage in the dark and seeing the break down, I know 'how those long winter evenings must fly by', but bl**dy found it eventually !!!
Old 23-Aug-2006, 21:37   #12
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Originally Posted by Jools
Bugggerit...if I'd known they had one of those at the trackday
Yeah, I've just had a little swear too.
My main problem is that I don't have the time to get it to anyone with a diagnostic machine before I'm due to catch the Eurotunnel on Friday evening. So, I'm prepared to try everything I can myself at this stage!
Maybe a diagnostic machine is the only way to go......
Old 23-Aug-2006, 21:40   #13
Perhaps I'm being ignorant - very possible - but I don't quite understand. Please excuse me, but what is an "HT cable" and how did spraying water on it in the dark help you to see the break down?
Old 23-Aug-2006, 21:45   #14
DaveB916
HT cable is cable that goes on spark plug, you can see it arcing to heads or frame depending where the insulation is breaking down, hence it discharges there and no spark at plug = misfire tends to happen under load and more if damp.
Old 23-Aug-2006, 21:52   #15
OK, great, now I understand. I'll check the insulation around them tomorrow at least. Thank you
Old 23-Aug-2006, 22:02   #16
DaveB916
I know this may sound bizzare but:
If you can take it for a ride in the dark with the side panels off you will see the arcing very easily if the insulation is breaking down, alternatively as a very short cure bind the HT cables with insulating tape, but the tape will also fail soon if the cable is breaking down.
Also had this happening with a Subaru when under full boost, more difficult to see in the dark tho'.....lol
Old 23-Aug-2006, 22:06   #17
If it works for 3 days over the weekend in France, I'll be very grateful. So, I'm going to try this anyway.
Old 24-Aug-2006, 07:41   #18
Someone has suggested to me that the problem might be the engine temperature sensor on the front cyclinder. They only knew about Monsters but thought Supersports might be the same. Apparently this sensor can be "fiddled" with to run a richer mixture.
Anyone know more about how to do this? Or if indeed it's worth doing?
Old 05-Sep-2006, 15:28   #19
OK, so I took my bike into the Ducati Proteam and Wimbledon. I needed to get things fixed quickly and I wanted somewhere close to home, so I chose these guys for the first time.
Just been on the phone to them and apparently my "trimmer" was set to -55 which has leaned the mixture right out. They've reset it to -10 (factory setting is 0 I believe) and the bike is running fine.
Can anyone tell me what else a "trimmer" might be called and what it does/how it's set etc???
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:47.
