Old 31-Aug-2006, 22:31   #1
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
Do you really think you need to spend much on your 583 Lucie? Chances are it'll be fine with new belts and valve clearances done, a bit of piston slap when cold is perfectly normal on the older 583 engines, and the bottom ends are pretty solid and don't tend to wear out. If it was me I'd fit new belts and let nelly set the valve clearances, spend no more on it than that apart from oil and filter change, and keep on using that for now. If it should go bang for any reason, switch to the 620 for the rest of the season!
Old 31-Aug-2006, 17:00   #2
phil_h phil_h is offline
phil_h's Avatar
Originally Posted by multi600
You could run both bikes with a bit of luck, help to get the gird numbers up.
I think its a complete waste of time imagniing that NE will be interested in running 2 DD grids.
Or ever have been.
Old 31-Aug-2006, 16:58   #3
phil_h's Avatar
Have you not ridden them both back to back Lucy ?
I have a smilarish dilemma since the prospect of 2 grids has evaporated.
I really like hooning around on the 583SS, as it is so easy to keep it pinned for most of the time that it _makes_ you try and get better corner speed.
That alone makes it fun for me, but I suppose it also lets me stay in my comfort zone more.
The 620 delivers the power so much more willingly that I find I have to shut off more often, and that is a challenge in itself when I'm trying to learn to be smoother in the corners.
But that makes it more of a challenge than the 583, and makes me ride faster lines more often !
In the end, at donington, I chose the bike that I thought I was more comfortable on for the race, and did actually achieve better times than I did in practice.
If you cant get both bikes to snet, but can blag some extra practice time, you can borrow my 620 if you like. Alternatively, its 25 for an extra race
(even if it is raining, you will still find out something by riding both bikes back to back !)
Old 31-Aug-2006, 17:01   #4
Grib Grib is offline
Grib's Avatar
Mood: Ducati-less!
Chass....if I thought that was possible it wouldn't even be an option
Tonio...I know, but I'm always broke
Phil...I haven't had the chance as yet. Thanks for the offer, but I'll drag the SS and Mong out somewhere for a trackday and see how I get on
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:50.
