Old 21-Sep-2006, 00:07   #11
Red-Duc Red-Duc is offline
Red-Duc's Avatar
Wink
Been out for a ride tonight, Rpm is 5500 at 100 mph with a 37 rear sprocket, Looks like i should go with the 39t rear.
opps forgot to mention, test was done on a private road
Old 21-Sep-2006, 15:45   #12
Interesting - tried it the other day 100mph = 5600rpm on a 41T rear
I told the officer I had to try this test out for DSC purposes!
Cheers - Frank
Old 21-Sep-2006, 15:58   #13
Red-Duc's Avatar
Frank what front sprocket you using?
Old 21-Sep-2006, 16:09   #14
psychlist's Avatar
Mood: Lucky? For some, maybe!
Question
When you're comparing speed/revs on bikes, make sure you really are comparing like for like. Quite a few changes were made to primary drive ratios through each models life.
Old 21-Sep-2006, 16:44   #15
Red-Duc's Avatar
Not sure what the other bikes are but ive got
97 SL MK5 15 front 37 rear and at 100 mph pulling 5500 revs
Old 21-Sep-2006, 17:48   #16
ziggi ziggi is offline
ziggi's Avatar
Ah! Now I've also got a 170/60 section rear tyre (newish Pirelli Diablo). I reckon a 180/55 section rear tyre would affect it somewhat also.
Interesting all the same
Old 21-Sep-2006, 19:33   #17
Paul has a very valid point about final gearbox ratio's
Red-Duc, front sprocket is a std 15T I believe.
Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:56.
