Old 11-Oct-2006, 17:22   #11
Mr.R Mr.R is offline
Mr.R's Avatar
Originally Posted by jgriff
http://cgi.ebay.com/ebaymotors/OHLIN...38157079QQrdZ1
Or you can use a DU440 but the hose is only 440mm so you need to get a longer hose. Get them from the US for about US$700. Shock lenght is 330mm. As far as I'm aware all 851/888's except the tricolors (I'm not sure on them) have the same dimentions for suspension.
And why do you guys go on about the "SP rocker" my what was standard 1990 851 Biposto has one.
Griff
Hi, latter strada had a cast rocker and different yellow arm,they can't be mixed and matched.
Steve Robins S.W.
Old 11-Oct-2006, 21:32   #12
851neil 851neil is offline
Mood: need a bike...
Griff, the SP version has the ride height adjuster and the casting is also totally different. I'll see if I can post up some parts drawings tomorrow.
Old 11-Oct-2006, 21:42   #13
paynep's Avatar
Mood: Wet wet wet
Bugger, does that mean that I can't use the SP/early adjustable setup on my 1992 851 - which has already got an Ohlins on it?
My Ohlins is a DU807, which was listed for the SP as the reservoir routes best to the lefthand side of the subframe. my 851 is like a 888 Strada with the reservoir on the right so there is a bit of cable tie action needed. One day I'll get an SP subframe....
Confused of Alton
Old 11-Oct-2006, 22:50   #14
jgriff jgriff is offline
jgriff's Avatar
Steve Robins S.W.
Yes I know I have one sitting on my bench. The rocker and the hoop must be changed as a pair. Also early 851's took different eyerod ends. But the rising rate geometry is always the same. Frame lugs in same place, swing arm lugs in same place, shocks are all 330mm long. This is what I can gather from looking at the situation very carefully. If I'm wrong I'd appreciate new information.
Griff
Old 11-Oct-2006, 23:36   #15
Jasper Jasper is offline
Jasper's Avatar
My SP5 has a Du 8701,with as already explained,adjustable eccentric in the the top rocker.Strada U-Hoop's will not fit this rocker.Or vice versa.
Old 12-Oct-2006, 11:40   #16
paynep's Avatar
Mood: Wet wet wet
Griff
Hooray, sounds like I can use my adjustable rocker and matching hoop - which happens to be yellow as well :-)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:55.
