Old 16-Oct-2006, 13:35   #11
Originally Posted by moto748
If you listen carefuilly (engine off, ignition on) you should be able to hear a "click" from the front brake microswitch. If you can't hear a click, the switch is misplaced/missing/broken.
They can become displaced. Mine has two tiny lugs which locate in two holes in the handlebar switch/master cylinder assembly, although I believe there are two different types. Pull the switch out, give it a squirt of WD 40, test that it works by pushing the button, and carefully reinstate it.
Yup on on the monsters we have to use a small piece of crumpled of tin foil to make the connection and make it click - I know - been trying to sort ours out all weekend
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:23.
