Old 15-Oct-2006, 16:21   #11
MonstaTom MonstaTom is offline
MonstaTom's Avatar
Originally Posted by phil_h
Or it could be that the idle mixture is still set pretty standard, and hence waaaay too lean, and the weather just got colder.
Set the idle mixture screws at 4 full turns out.
all dyno jetted and set up.
Old 15-Oct-2006, 16:23   #12
MonstaTom's Avatar
Originally Posted by nelly
pick ups and ignition units are notoriously fragile on them. Pull the plugs and see if both are giving strong sparks.
thats wot i was thinking as the spark didn't look that strong but the battery was starting to get low by this point.
Old 15-Oct-2006, 16:28   #13
MonstaTom's Avatar
anyway in the end i put jump leads on to it from the van and the original plugs in and eventually it went. i think the cold had a lot to do with as carbs were set when it was hot and i've found a few batterys that seem to give less effort in the cold ( bit like me then).
cheers guy's.
Old 15-Oct-2006, 16:43   #14
Monty's Avatar
There's a new easy start available from New Zealand-called-wait for it
"Start Ya B.a.s.t.a.r.d"
So titled because the makers reckon they are the 3 most uttered words when a vehicle won't start.
Growing old-disgracefully!
Old 15-Oct-2006, 16:56   #15
doogalman's Avatar
Tom, you better get out now and see if you can catch some of the late brigade. The rest of us are now looking forward to next week.
Maybe you should leave it idling outside the house so you don't have to worry if it will start or not next sunday
Old 18-Oct-2006, 23:54   #16
katana katana is offline
Mood: Annoyed and confused
Nah just leave the bike wrapped in an electric blanket
Old 19-Oct-2006, 00:12   #17
Can I just suggest that you buy a new set of plugs ?
Only its all I have to do to the 3 583's in this household when they decide not to play ball - cleaning seems to make no difference - new ones do!
Just my expereince like.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:00.
