Old 30-Oct-2006, 10:29   #11
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Theres not much in it to be honest..mines QB GF but some of the lads have the ricambi one and recommend those too...
Old 30-Oct-2006, 12:40   #12
aka.eric aka.eric is offline
It is possible to buy the SP seat pads,had mine from Germany.But,I found it to be a better job to use the Strada seat pad,your weight is then on the frame not the seat unit.Fitting involves cutting the seat unit,but its straight forward enough and no worries about stress cracks!.If you would like any pics just shout.
Old 30-Oct-2006, 13:25   #13
graham graham is offline
any pictures would be great
Old 30-Oct-2006, 17:11   #14
The Ricambi seat mould is taken from a race seat,so there isnt access to the underseat area (unless you cut a hole out),on the plus side,it helps to produce a stronger seat.
Old 30-Oct-2006, 17:13   #15
To use the Strada seat pad,a section is cut out of the seat unit.
Old 30-Oct-2006, 17:16   #16
The seat pad then fits as per a Strada,your body weight is on the frame not the seat unit.Once the seat is bolted on,its impossible to remove the pad.The fixings have to be removed which allows the front wings/side panels to move apart,seat pad can then be removed.
Old 30-Oct-2006, 17:19   #17
Two brackets(mounting holes already there) hold the unit at the required height/postion,rubber washers keep the vibrations at bay.I welded a nut under the bracket,seat then bolts on
Old 30-Oct-2006, 17:22   #18
Foam keeps the vibrations down at the back edge.
Old 30-Oct-2006, 17:23   #19
The end result.
Old 30-Oct-2006, 19:10   #20
thanks for all the input.
it looks like the QB and the Rimcambi are all copys of a race seat and all need some work somewhere to get a good resuilt but i have seen the picture of the sandbar seat unit and it looks like a 100% copy of the SP seat has any one fitted one and what do you think
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:34.
