Old 12-Nov-2006, 21:15   #11
Thank you - Cheers
Old 23-Nov-2006, 09:14   #12
adk adk is offline
Hi there,
have you worked out if the newer pegs will fit on your old stylee SS yet?
Cheers!
A.
Old 24-Nov-2006, 23:35   #13
Hi adk,
Yep - I think the new style pegs will work (for me!).
The 70mm center to center mounting points are right but, the difference appears to be that the exhaust mounting point is BEHIND the peg on the later models - which is just what I'm after IF I'm going to stick with trying to fit my low level Sil Moto's - so wifey can go on the back sometime.
I'm still toying with the idea of flogging the Sil's and getting either a standard set or some with seperate link pipes to provide more alignment provision.
Something to toy with over winter - but, a set of Kehin carbs keep calling me
Cheers - Frank
Old 25-Nov-2006, 11:06   #14
Monty's Avatar
Frank. Dellorto's are cheaper and will work just as well-drop as message to Paul Paine, I know he was fiddling with carbs on his DD bike.
John
Growing old-disgracefully!
Old 25-Nov-2006, 23:51   #15
Cheers John - I've also read good reports about Mikuni downdraught carbs as they have a built in choke!
Thing is - Chris Kelly at Ca-Cycleworks does a COMPLETE and almost totally fettled kit for the SS series ( + loads of experience to back it all up).
Pretty hard to resist.
Cheers - Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:00.
