Old 07-Nov-2006, 18:44   #11
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Good clip on can be had from Geoff at Baines. He does some for his Imola project that are slightly lower and longer than standard. Got them on mine. Great.
Rgds,
Rob
Old 07-Nov-2006, 21:23   #12
Mr.R Mr.R is offline
Mr.R's Avatar
aka eric, says the factory manual doesn't give a height for the top of the forks over the top yolk, he's right!...But it does give a figure for the height from the bottom of the bottom yolk, which when everything is assembled gives a height from the top of the top yolk, to the top of the flange, below the large hex of the top nut of 12.5/13mm. This is the standard setting for Showa forks ( it shows about 10mm of the gold fork leg above the yolk ). This is the base line, when deciding wether to add or subtract any ride height from the front forks.
Steve Robins s.w.
Old 07-Nov-2006, 22:42   #13
aka.eric aka.eric is offline
Good spot Mr R
Not a very good scan,but the measurement is 263mm.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:34.
