Old 06-Nov-2006, 15:19   #11
Dave 90% of the time this problem is caused by the connector block in the back of the starter solinoid not making a good contact or even falling out, you will see many a Ducati with it tie-wrapped in, often just wiggling it while pushing the start button works, well it always did on my old 916
Old 06-Nov-2006, 15:24   #12
The sidestand bypass might still be the issue, it was on Lily's bike...
Old 06-Nov-2006, 15:26   #13
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
I'll have a look at all this tonight and report back.
Typically I've just sold it and now it want's to mess me around
Old 06-Nov-2006, 15:32   #14
I had similar on my ST and it was one of the relays gone a bit green round the gills. Trouble is that there are so many interlocks that without a wiring diagram it's difficult to say....why did my 888 fuel pump refuse to work when one of the fuses in the fuse box was loose? Nothing to do with the fuel pump fuse but must have been in the circuit somewhere.
___________^
Old 06-Nov-2006, 16:22   #15
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
same thing happened to my 916, it was the solenoid
there is a white two pins connector, check that this is not loose.
I still changed the solenoid and all was well
Old 06-Nov-2006, 16:38   #16
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello Dave996
as Skids says above, the solinoid is in red and No.22 sometimes works lose
may work checking all connectors to the battery.
good luck
TopiToo
Old 06-Nov-2006, 17:45   #17
Martinp Martinp is offline
Martinp's Avatar
Mood: 748ish
I had a simular problem on my 748 turn out to be a dodgy earth from the alarm.
Just my 2p.
Old 06-Nov-2006, 21:16   #18
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
little yellow wire in the back of the solonoid! should do the trick
Old 06-Nov-2006, 21:28   #19
dave996's Avatar
Mood: Fed up...
Loose earth from the battery to the mount behind the rear brake resevoir. (At the resevoir end)
Cheers for all the advice
Dave
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:17.
