Old 15-Nov-2006, 22:21   #11
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Ive got a brand new 998s ECU here if you need to try that mate..
Nat
Old 16-Nov-2006, 10:31   #12
Monomoto Monomoto is offline
Mood: Mad as a box of Frogs
I did once have a similar problem, it turned out t be a bare length of wire o the back of th fuse board...Maybe you haven't checked that ??
Best of luck
Monomoo
Old 16-Nov-2006, 17:44   #13
ROACHMAN ROACHMAN is offline
ROACHMAN's Avatar
Ive cleaned all the connections I can find but to no avail
Nattyboy, Ive replaced the race ECU with the road ECU but that hasnt cured it either.
I am wondering if its the connections to the ignition barrel - I hope so , I will look at it at the weekend.
When the bikes switched off the parking light works. When the ignition is on the idiot lights work fine but when I put the lights on or the indicators the idiot lights go off ??
Old 16-Nov-2006, 17:46   #14
ROACHMAN's Avatar
Its got to be something simple but I am running out of ideas. I cant afford to take it to the dealers. Bikes been off the road for 2 weeks and counting
Old 16-Nov-2006, 18:15   #15
crm250 crm250 is offline
crm250's Avatar
Mood: Firing on all 4 !!
This sounds like a bad earth. have you checked the earthing points to the frame ? other place to look would be the swivel connector on the righthand side near the airtube connecting the front loom to the main section. mine was also doing some odd stuff until i replaced the whole loom with new sections. all odd faults suddenly vanished. does it have an alarm fitted ?
Old 16-Nov-2006, 18:20   #16
testastretta testastretta is offline
testastretta's Avatar
At first I thought it sounded similar to problem seen on 749/99 - if pump fails to energise its normally the cheap little relay located (on 749/999) at base of battery compartment - but failing lights and spurious rev readings ? Its possible there are more than one faults of course, check your fuel pump relay anyway.
Old 16-Nov-2006, 18:31   #17
ROACHMAN's Avatar
CRM 250
How many earthing points are there?
Ive checked the one that goes from the -ve battery terminal to the engine.
There isnt an alarm fitted
Old 16-Nov-2006, 18:42   #18
Hence my earlier post in this topic about running seperate earths
Old 16-Nov-2006, 18:50   #19
ROACHMAN's Avatar
OK Skids,
Ive got a voltmeter but im not very electrically minded. If I unplug the temp guage is it just a matter of sticking the voltmeter probes in with the ignition on, is there any risk of short circuits ??
How do I do your other suggestion of an additional earth. Do I just run a piece of wire from the -ve battery and stick it in the temp guage -ve ?
Old 16-Nov-2006, 19:30   #20
If you get no joy try an auto electrical centre, just watch what they charge you.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:25.
