Old 30-Nov-2006, 19:44   #11
ah, ok thanks. Where would I get one of those and are they a standard fitment?
Old 30-Nov-2006, 20:04   #12
If you want one that gives you a lighter action see Nelly/JHP.
Old 30-Nov-2006, 20:12   #13
Bungi Bungi is offline
Originally Posted by bradders
so which would you go for mate - 16x18 a good compromise on the clutch?
you could opt for a 19x20 which if you have a std slave cyl wil give you a lighter clutch
Old 30-Nov-2006, 21:32   #14
ok, that might be the way then coz the italian geezer sells em at the same price
Old 01-Dec-2006, 03:33   #15
You've got it reversed: the smaller the clutch master cylinder diameter -the lighter the pull; the larger the slave cylinder diameter - the lighter the pull. So, the (early) 13mm stock master has a lighter pull than the 16mm Brembo radial which has a lighter pull than the 19mm diameter of the 19x20.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:47.
