Old 30-Nov-2006, 16:18   #11
dema582 dema582 is offline
Hi guys,
Just saw one on JHP's website. Not sure what it's like but if it's anything like their other products I'm sure it will be good.
www.ducaticoventry.com
Old 30-Nov-2006, 16:42   #12
pedro pedro is offline
pedro's Avatar
Mood: r
its the first "mod" i did on my 999,it had a better feel to it over the standard throttle,its not as loose as the standard. it feels just right as i have limited wrist movement.
Old 30-Nov-2006, 20:22   #13
Bungi Bungi is offline
Originally Posted by khushy
this is NOT a good idea as it only has one cable - the 749/999 has two - open and close is controlled by the cable and not by the return spring!
Khushy
Yes the 999 has 2 cables for a reason, im told this is because when the engines are in a tuned state (with the single cable throtles) the racers were experiancing a delay in the engine shutting off after hacking down the straight. the 2 cables means that when backing off the throttle this manually closes the butterfly,
so if protwins are doing a spring modification then this would appear logical, should this info be accurate.
Old 30-Nov-2006, 21:42   #14
Simon Reed's Avatar
Mood: Cool as **** !
Originally Posted by testastretta
Where did you get the beautiful grips with red cut-outs ? Been looking for these .
Anne Summers wasn't it khush ?
Old 30-Nov-2006, 21:43   #15
Simon Reed's Avatar
Khushy
All the quick lads,and racers use this mod ,anyway,ner ner na ner ner !!!
Old 30-Nov-2006, 21:59   #16
back to thread....any good on a 996 bike?
Old 30-Nov-2006, 23:10   #17
I think that this is because until recently there has not been much option other than fitting the 996 twistgrip etc,
Old 30-Nov-2006, 23:12   #18
what wrong with the 996 throttle that you have? the 999 range need it as they operate over about 90degrees as std
Old 01-Dec-2006, 05:25   #19
Have a look here;
http://www.busters-accessories.co.uk...asp?prod=PG724
Old 01-Dec-2006, 07:58   #20
nothing, but I didnt ask the original question altho always interested to know if there are improvements avaiable that are worth doing
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:49.
