Old 31-Dec-2006, 17:18   #11
9rrr 9rrr is offline
ratios
Thanks for that. All the best to you all.
Old 31-Dec-2006, 17:21   #12
There's a "sweet spot" - around 4,600 RPM @120Km/hr in 6th gear for liter displacement superbikes, a little higher for 74X's. Obviously, faster tracks will require rear sprockets with fewer teeth, slower tracks more teeth (and possibly longer chains.)
I strongly recommended NOT changing the stock front sprocket or chain size for safety reasons. Just my opinion.
Old 31-Dec-2006, 20:25   #13
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Shazaam!, I used this very chart that you kindly provided earlier in the year when I changed my gearing. Only problem being the listed sprockets for the 996R are incorrect. They have a 36 tooth rear as standard. Apart from that its a great bit of info.
Happy New Year!
Old 01-Jan-2007, 02:01   #14
Thanks Martin. The data's been corrected above.
Old 24-May-2007, 13:31   #15
Stealth Stealth is offline
Bikes: 998R, Panigale S
Stealth's Avatar
Dear Shazaam
Table not visible just a little red cross in a white box. Could you kindly e-mail
many thanks
Tim
Old 24-May-2007, 13:48   #16
BDG BDG is offline
BDG's Avatar
From memory i'm on 15 38 on my 6R.
I did briefly try a 14 tooth front to test the results before investing in a rentahl rear sprocket carrier. Larger rear sprocket for same results, less stress on chain and safety reasons Shazaam has expressed.
Front wheel comes up very easy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:47.
