Old 30-May-2003, 21:38   #1
Felix Felix is offline
The bearings will have to be brayed out. You have to move the spacer off to one side so that you can get to the back side of the bearing with a punch by sticking the punch through the axle hole. The bearings are not meant to be removed and reused, if that's what your thinking. The only time you remove the bearings is when the need replacing in which case it doesn't matter if they get damaged.
Old 30-May-2003, 21:54   #2
rocket rocket is offline
cheers felix fortunately , the wheels i am buying have them in already Thank god i don’t have to take them out.
did try but could not get them to shift
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:46.
